Big Truck Technical Discussion...
ISX Related Help
> Just a PM and a peep
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
Volveezy70005
06-23-2020,
Did a oil change on the 2250 and took the valve cover off currently at 610,000 miles I use Rotella 15w40 with some gear oil however I noticed some shadows on the cam. I think it might be normal wear or should I be worried or nahhhh?
SquareOne
06-23-2020,
Could you post some close-ups of the tops of the lobes or the areas you're concerned with?
ISX Related Help
Reference URL's
Rawze.com: Rawze's ISX Technical Discussion and more:
http://rawze.com/forums/index.php
