08-12-2020,
So after sitting at home for 4 months and then getting back to work ASAP!
My frankistien of a cm870 has been serving me like the good al mighty! Has been great so far I haven’t had any issues on the motor but more so on the Volvo side. Mainly electrical issues here n there and sensor in or around the cab.
I recently bought both of the belt tensioners, was only able to replace one of them since the other one has the Allen bolt going threw it that runs the ac compressor. The SOB is a little stripped so once I get more then 2 days of I can get to it properly. The markets are hot and some more then others so might as well keep working while it’s going strong.
Replaced the belts also while I was at it n didn’t see a need to skimp out on $160 worth of belts vs the tensioners came out $600 for both....
Also replaced the carrier bearing for the first time!.... that was fun... lots of fun when the sun was beating down on me at 105 degrees for 2 days. I struggled for 2 days, also figured out I have a bad drive shaft that connects to the first differential.... gonna have to replace that as well shortly or as soon as I can. I had a big scare that my ECM was going out but thankfully It wasn’t the case, it turned out to be just some bad wiring job on my end.
I finally got a fridge and inverter installed in the truck! This has made so much happier and healthier! Also saved a ton of money not eating all that shi#t food From the truck stops.... the food was making me sick n worse by the day!. Thankfully I was making enough to get that out of the way. I got 3k watt inverter from harbor freight, got it for a good deal/hook up since I’m in there every weekend lol. I know it’s not a pure sine wave inverter but it’s gonna have to do for now, I’m only using one thing at a time. Don’t wanna burn anything out or w.e.
I hope everyone has been doing good so far and keeping in good health!
