02-26-2016,
02-26-2016,
(02-26-2016 )smitty1243 Wrote: [ -> ]does anyone know what problem this code is for.
From what I am getting, it is a DOC Inlet temp alarm.
The FMI number will help with what inlet temp alarm it actually is.
02-29-2016,
(02-26-2016 )Rawze Wrote: [ -> ]fm2(02-26-2016 )smitty1243 Wrote: [ -> ]does anyone know what problem this code is for.
Data erratic or intermittent. It is likely bad wiring or dirt in the main harness connector going to the DOC/DPF.
Pull the connectors apart, inspect wiring for places rubbed thorough, and clean the plugs out with contact cleaner.
If it persists, replace the inlet temp sensor.
Thats just what i would do any ways.
03-06-2016,
(02-29-2016 )smitty1243 Wrote: [ -> ]thanks(02-26-2016 )Rawze Wrote: [ -> ]fm2(02-26-2016 )smitty1243 Wrote: [ -> ]does anyone know what problem this code is for.
03-09-2016,
so i ended up changing that sensor they said there was a short, drove truck about 8 days and lite come back on now it says fmi 18 4364.....man the fun never stops. is there a web site where i can get these codes? thinking of getting insite program any suggestions as i see there are different versions. i have 2250 motor.
03-09-2016,
Cummins quick serve has all the codes on it. Just sign up and enter your engine serial number
