07-29-2016,
So after fighting with this code for a couple of weeks of it coming on and off, the truck would loose power for a split second then come back only here and there. The truck started to shut off and that's when I knew the problem was getting worse. After 2 days of testing fuel pressures, fittings, hoses, injectors, fuel pump my mechanic came to the conclusion it was something with not 1 but both tanks. Truck turned on fine and had no air when he canceled both tanks. Even when he would hook 1 up it would get a lot of air. It ended up being the pick up tubes!!! Both tanks!!! Unilevers called it either air or fuel pump actuator..... Truck turns on now and idles smooth and got power back!!
Next is bypass oil filter next oil change.
