Hi Guys. I have an ECM and have borrowed a bench harness. I can hook up ok with insite and can see a list of active faults, i assume cause its not hooked up to the truck. How do i go about copying the ecm file to email it to Rawze. Any help would be great ive never done it before.
Thanks
You need c@term to pull a copy of the program, insite won't do it.
thanks, i do have cterm but still wont open. as well i cant clear the codes i assume because the truck is not hooked up. or is there another file i need
You need the right engine configuration file.
I found enf is that right for a 870
Honestly I can't remember and I can't check at the moment.
(02-08-2021 )2dlb Wrote: [ -> ]I found enf is that right for a 870
Any news on this? I would also be interested in knowing how to pull a file.
You need to search out and aquire calterm and the directions you seek are in what the internet knows as mama's m ilk money files.
That’s for the cm871 not a cm870 ! Will this still work for an cm870?
