02-26-2021,
So when you guys blocked the turbo and aired up the system you found the leak at the compressor, right? I’ll have to give that a try. Did you hear it back feeding through the compressor, or how were you able to verify the compressor was leaking?
If the compressor is the culprit would I notice that the compressed air system wasn’t performing as usual?
