Have a question it it normal to upgrade insite when you get it mine is 8.1 and it’s asking to be upgraded
Prob not unless you need to. You may not need 8.1 either depending on the year of your truck, then you can stop paying the yearly fees.
It’s a 2013 and have it put on the password in it says insite has expired upgrade
If fees are paid up to date, prob will have to upgrade.
Just want to say thank you to everyone that help me out with the insite it’s up and running
Thank you again
Having a problem with the inline 6 insite reading the ecm going to try again tomorrow I’m charging up the laptop
(03-13-2021 )JAsaro Wrote: [ -> ]Having a problem with the inline 6 insite reading the ecm going to try again tomorrow I’m charging up the laptop
Mine takes more than a few tries.
(03-13-2021 )amermextrucker Wrote: [ -> ] (03-13-2021 )JAsaro Wrote: [ -> ]Having a problem with the inline 6 insite reading the ecm going to try again tomorrow I’m charging up the laptop
I hope it work going to try again tomorrow laptop died the laptop is old maybe that’s the problem?
Update it’s working now I didn’t realize that the inline6 software wasn’t downloaded into the laptop
