How full was tank when you checked temperature? Was you touching to the top of the tank? Passenger side is always hotter because engine is hotter on this side. Fan blowing air under cab and fuel tank top where is no fuel is always feels hot. Check temperature on the bottom of the tanks.
(04-17-2021 )tree98 Wrote: [ -> ]Would be nice to know exactly how hot the fuel is getting, maybe it isn't even that hot and your chasing non existent problems.
I’m going to have to get one of those laser pointer thermometers to check the temp.
(04-17-2021 )snailexpress Wrote: [ -> ]How full was tank when you checked temperature? Was you touching to the top of the tank? Passenger side is always hotter because engine is hotter on this side. Fan blowing air under cab and fuel tank top where is no fuel is always feels hot. Check temperature on the bottom of the tanks.
Just stopped to check it and driver side is cool but passenger side is hot.Tanks are just under 3/4 full and I touched towards the bottom.I can only hold my hands there for three seconds before it’s too hot to touch.
Your head must be getting extremely hot??? Is it running ok and everything normal?
(04-17-2021 )tree98 Wrote: [ -> ]Your head must be getting extremely hot??? Is it running ok and everything normal?
Coolant is between 180-190.Oil I don’t know because gauge is broken and I have one getting here next week.
(04-18-2021 )tree98 Wrote: [ -> ]Insite will tell you
Should have it by the end of the week.
I got the infrared thermometer and measured it the other day but don’t remember the exact numbers lol.What I do remember is that there was a 20 degree difference.
