04-13-2021,
Finally got it cranked up today. Fresh inframe. All cummins parts, new head, all the going recommendations you would expect to see on here. All new sensors, cams new, IFSM all new, yts turbo, front structure gasket, all gaskets, hoses and O-rings replaced. I was pretty far into this.
Engine has the older style pump, NOS, that had 8 dimes put into the cup in the bottom of the relief valve.
Engine starts and runs great. No odd noises or anything of the sort, not even a check engine light. Engine starts with high oil pressure that drops to about 22 as it warms up at idle. Oil pressure climbs with RPM, up to 85 at 1500. Obviously can't drive it this way, tomorrow I'm dropping the pan to check the pump. It appears that the regulator is working.
Just to clarify, this is the older pump that uses the same diameter idler and driven gears and the regulator is held in with a cotter pin. It has 8 dimes in it and they were installed when the pump was vertical (so the dimes played flat).
I will be verifying the pressure, though I'm pretty sure it's high...the engine sounds like a waterfall when I shut it off, there is so much oil in the top running back into the pan.
Anything else to look out for? I'm thinking of disassembling the pump to make sure there isn't some trash in it or something of the like. I'm also wondering if maybe installing the dimes in the bottom of the regulator valve vs the bottom of the bore in the pump body was a mistake...?
