I have a 2003 international 9900i and the oil temperature gauge is toast.Looking for a better replacement for it.
I have replaced mine with factory ones
(04-20-2021 )Luckyjayb Wrote: [ -> ]I have replaced mine with factory ones
I found a used one on eBay.Where did you order yours from?
Have you tried the dealer?
(04-21-2021 )tree98 Wrote: [ -> ]Have you tried the dealer?
No all I did was search on the internet and what I mostly found was digital ones until I found the used one on eBay.I’m going to have to check out the local dealer next time.Thanks.
Yep, dealer can order them. Where I had to get mine. Used would probably be fine as it's not a common failure.
Dealer guage price was just under $300 with tax.
All the 9000 series trucks used the same gauge for many years. You can probably find a salvage yard take out really easy for cheap.
(04-23-2021 )Chamberpains Wrote: [ -> ]All the 9000 series trucks used the same gauge for many years. You can probably find a salvage yard take out really easy for cheap.
That’s probably what they sold me.$27.95 on EBay.
