09-13-2021,
I had a low voltage disconnect switch on a 2014 Cascadia get damaged and the truck wouldnt start. The switch on the floor next to the seat. Luckily the driver was able to use a pliers and get it turned far enough to get it working enough to get back home.
Is there a way to bypass the switch if I run into this issue again? Its a 4 wire plug in so I am not sure how it works and I cant seem to find the correct wiring diagram for it.
