My oil temp gauge hasn’t worked since I purchased my truck so I purchased an OEM used one and it didn’t work either.So I’m wondering if the Glow Shift oil temp gauge sender will work on a cm870? And also where would it hook up? TIA.
I have a set of there gauges in my dodge. they look good but there sensors are pure shi#t
First one last maybe a year and started pouring fuel from it, this ones a few months old and is not very accurate (within a couple psi)
(10-13-2021 )RollinCoal Wrote: [ -> ]I have a set of there gauges in my dodge. they look good but there sensors are pure shi#t
Will I be better off with a Teltek?
