10-18-2021,
2014 Prostar - Cummins sleeper Truck - LIttle Background NOT MY TRUCK by the way as i would never purchased this...... Customer purchased truck and Body Controll Harness had butt connectors close right where plugs in ECM - Big RED FLAG, but what done is done.
Accelerator Pedal Shorted High Fault - Replaced Pedal Same Issue, tried a 2nd Pedal even same issue. Tested OHM,PWR, Pins etc anything to do with pedal.
Replaced the Entire Body Control Harness with New Factory Ordered Harness !
NOW Still have 2 pedal Faults along with couple more now..
SPN 91 FMI 4 - Accelerator Pedal Position
SPN 2623 FMI 4 - Accelerator Pedal #1 Chanel 2
SPN 2023 FMI 3 - Fault on Analog Input 4 above normal when used for ambient light - Something to do with CLuster
SPN 639 FMI 2 - Drivetrain Message Timeout.
So throwing it out there to see if anyone has had a similar issue.... A bit lost
