I have a 2012 KW W900 that I need the abs wheel speed sensor connector for the chassis side of the harness. The instructions with the sensor call it a "standard round 2pin connector". It is a male connector, I need the connector shell, terminals, and seal. Kenworth dealer says they don't have access to the part numbers because kenworth does not want anybody repairing the harness because of liability but want you to replace the harness. I refuse to give in and spend they're $1800. However in the parts book they give me a connector part# P20-6064 but that is the shell only. Anybody know where I can get the terminals and seals to repair this?
(10-22-2021 )tree98 Wrote: [ -> ]Junk yard maybe
Yes but those terminals are already crimped so my only option would be to use it as a pigtail and butt connect it. I would like to eliminate any extra splices to reduce potential sensor signal problems. I'm rather OCD about doing perfect wiring jobs and completely capable if I can just get the parts.
Electronic component stores Mouser or Digikey.
Take a picture of the connector your talking about and post it here. We've found quite a few original manufacturers amd aftermarket manufacturers of some strange plugs before. I believe we'll be able to find you something that will work.
(10-23-2021 )Chamberpains Wrote: [ -> ]Take a picture of the connector your talking about and post it here. We've found quite a few original manufacturers amd aftermarket manufacturers of some strange plugs before. I believe we'll be able to find you something that will work.
Hare are some pic's. the back of the shell has says APE-P2P on one side and PBT ITT-C on the other side.
