10-24-2021,
(10-24-2021 )CANNONBALL Wrote: [ -> ]Attached is what quick serve says off the ESN. Cam and bearings are always coated with way more lubriplate than needed when sliding in cams. Always take it gentle and don’t force it. If it doesn’t slide together something is wrong. This one slid in. Oil holes were all lined up. Double checked them all. Did it all myself so I know how it went in. No issues during assembly. Cam turned it by hand just like the valve camshaft. Always try to bar the motor after every part installs to Make sure there isn’t any drag or anymore resistance. Cheap insurance I guess. That’s how mad dad always built them just always stuck with me.
I cant place blame on anyone but myself for using the head knowing what issues it had in the past. I’m not mad about it. Customer has been a good one over the years. He understood the risk and I wasn’t warranting anything that wasn’t Cummins brand.
Then if it was done right .. then there should be a warranty on that head .... though I would ask for the money back instead of a replacement head... and get an OE (brand new) head and put on it. That would also be the customers problem not yours if they are the one that supplied it. they should also ask for the moneys to replace the cam and negotiable labour costs for replacing it too. - Then offer nicely, to SUE(via their lawyer) for those things + lost revenue and costs of any additional down-time if this is not made right.
I know I would. There are laws in this country that protect consumers from defective products.. this sounds like one of those that are cut and dry.
