(08-23-2016 )axe Wrote: [ -> ] (08-23-2016 )74bassman Wrote: [ -> ]Where did you get the monroe shocs?? Do you have a part number??
I got mine at NAPA. I don't have the part number, but some of the other guys will hopefully chime in.
You could order them online Im sure also, probably cheaper if you don't have a good contact. My father owned NAPA store for over 40 years so I get pretty good discount.
(08-23-2016 )axe Wrote: [ -> ] (08-23-2016 )axe Wrote: [ -> ] (08-23-2016 )74bassman Wrote: [ -> ]Where did you get the monroe shocs?? Do you have a part number??
What kind of truck do you have? I thought in some of your posts I read were you had a Volvo. I have a Prostar but have had couple of Volvos in the past. Volvos are hard on front suspension, as someone else said put a good gas charged shock on there. Post year make and model of truck, gurus will be active ina while, they will guide ya.
Hopefully, spent over a hour at peterbuilt on the phone with rush trying to get part numbers. Rush kept me on hold, and peterbuilt couldn't cross reference any numbers. I now need to replace the transmission mounts also.
Mr Hagg what would be the turn around if I brought you the truck in the am, to replace transmission mounts, shocks, and damper
74bassman We are pretty backed up our selves. With one inframe and one getting a list a mile long. We might be able to work something in Friday but that would be the soonest. However as far as front end work I can call Hiil Tire in the morning and see what they can do. I also Have another shop we use for alignment here locally I can call if you want me to.
Prostar steers shocks Gabriels part#85954
Drives part#85931
Those are the cross numbers from the originals hopefully that helps so far on my prostar are holding real good.
Tried napa this AM, they said those part numbers are obsolete.
(08-24-2016 )74bassman Wrote: [ -> ]Tried napa this AM, they said those part numbers are obsolete.
Mine it's a prostar 09, I bought mines here at Fontana California try some other suspension shops
