12-15-2021,
Got a fault this morning on the x15 with SPN 6713 FMI 9 (FC 5177) Variable Geometry Turbocharger Actuator Software.
Told the truck to stay at home not go to work and booked it in with cummins tomorrow (it's still under warranty, and code says basically it's a new actuator).
However, I went to check the truck out, and wiggled around some of the harness cables and let the truck run and the code went away. I still have to try and connect this truck to insite myself as I was getting the weatherpack connector, because it's not accepting inside 7.6.2 even with a CAN1 to CAN 3 adapter.
Anyways, question is, the fact it may have just been some loose connection, is it good to run and see if the code comes again. Or - do I take it to the shop and just get the actuator replaced, and check the turbo for the sector gear movement as well.
