02-02-2022,
2015 CM2350
Got the following codes today and truck derated from 25%, 75% to stop:
- SPN 4340 - FMI 5 - Def exhauster fluid line heater 1 state - current below normal
- SPN 6802 - FMI 31 - DEF System frozen
DEF is not frozen. Def is 80%. Checked all the connectors at the DEF pump for physical damage and connection, nothing to note. I changed out all of the relays (3) and the 15 amp fuse on the aftertreatment box, no avail.
When running data logger, i can see that the 4 heaters are on. But Def temp stays between 55 and 60 F. Temp right now here is about 40 F.
Any tips or tricks besides the quickserve troubleshooting.
