(03-23-2022 )Rawze Wrote: [ -> ] (03-22-2022 )Redland1 Wrote: [ -> ]38 psi according to my Glowshift boost gauge when I’m loaded at 86,000lbs and the hammer down.
and how much fuel flow does Insite say it is giving it when it is doing this?
100 percent fueling.Picture is not so good but you can see the fuel percent and rail pressure.
(03-26-2022 )Redland1 Wrote: [ -> ]100 percent fueling.Picture is not so good but you can see the fuel percent and rail pressure.
that is fairly useless info,...what you need to monitor is the actual mg/stroke that its pouring into the cylinders rating.
(03-26-2022 )Rawze Wrote: [ -> ] (03-26-2022 )Redland1 Wrote: [ -> ]100 percent fueling.Picture is not so good but you can see the fuel percent and rail pressure.
I don’t see that on my Insite.Where would I find it? My version is the pro and not pro plus.
(03-27-2022 )Redland1 Wrote: [ -> ] (03-26-2022 )Rawze Wrote: [ -> ] (03-26-2022 )Redland1 Wrote: [ -> ]100 percent fueling.Picture is not so good but you can see the fuel percent and rail pressure.
Not 100% sure that Insite shows it... but I though I had seen it there before.
You might need the other software to see it.
ref:
http://rawze.com/forums/showthread.php?t...3#pid58693
