02-27-2016,
Long story on this one, and I will not bore you with it other than to tell you the buzzer itself from International is $155!
Ok, you jump in the truck, air is low and all you get is a click click click sound from the gauge cluster? No buzzer or bell? Here is how you fix this problem! Disconnect the battery, make sure it is disconnected by getting in the truck and make sure there is no power, or you are wasting your time! Reconnect the battery. Now go check your buzzer, it should work. I have no clue why this happens, but I have to do this reset at least once a year.
I hope this helps!
I hope this helps!
