Finally got my
Truck back together after having the engine out and rebuilding it Turn key on abs went to hit the start button and I have nothing. Starter relay clicking
starter going bad?.
is the engine easy to turn by hand?.
Yes I apologize. Starter was working before engine disassemble now it doesn’t make any noise or try to engage. What makes the starter engage. The little solenoid under the starter?
(05-10-2022 )Jchism3406 Wrote: [ -> ]Yes I apologize. Starter was working before engine disassemble now it doesn’t make any noise or try to engage. What makes the starter engage. The little solenoid under the starter?
its anyone's guess. you also did not mention what type of truck, engine, etc.
2001 Peterbilt 379 exhd. Cummins isx cm570
Make sure the cables are connected to the starter motor correctly. Apply 12v to the signal wire on the starter solenoid. If it cranks you have a problem with the wiring, ECM, fuses, keyswitch, etc....If it doesn't crank, the starter has failed.
