05-20-2022,
(05-20-2022 )ElJay90 Wrote: [ -> ]...
Everything you said is on point down to the theft. Ive already got a gps unit ready with subscription. Already have a dedicated laptop. Just was torn between cummins and paccar to buy otr or insight (iirc) but given you cant do in inframe on a paccar, im partial to cummins. Not a matter of if it will ever need a rebuild. Its when. Gonna be tough finding a unit with higher than 355 gears. Much less 4.11.
yes, it will be hard to find something with a short wheel base and 4.11's. This means budgeting about $4800 or so for set of rears (remans from weller are ok) if all other specs are ok, and putting them in right away along with all the other up front things that need to be done to it, like re-torquing wheel hubs, going thru the engine and emissions systems to clean it all up again, replace old sensors, etc.. replacing things on the truck that are worn out like shocks, bushings, etc. and all the other stuffs to get it reliable again.
As far as the Insite software goes... that stuffs in on the interwebs for free if ya look in the right places... just saying. The adapter and laptop is the important part of it.
Set yourself up for success. Do the things that a successful, wise Owner op would do, like the things that I mentioned above. Take your time to make sure you get what is needed and spec'd as such. Expect anything you buy to require you having to go thru everything to make it reliable again and do not take shortcuts. Get all of the maintenance schedule (all of the 120k interval, 250k interval, 500k interval, etc.) items done for the engine and truck to get it up to par. Do those things that make someone successful up front properly and the results for those extra efforts will show.
And yeah, the only advantage of owning a red engine is so that you have something you can work on yourself to keep after it so that problems do not plague it. Otherwise, if someone wants to do nothing but hold the steering wheel and run off to a repair shop every time it acts up, then the brand of engine will not matter so much because your going to be in a shop wasting all your profits every time the CEL light comes on.
