Hey everyone. I've got a fault on the information center that states "ABS J1939". Truck runs great, no derate or other accompanying codes. Truck made it an additional 6 hour drive home after code popping up. I've yet to hook up my laptop and insite to it. Does anyone have any information on this code? Where I should start? Is this best to have an actual mechanic look at?
Truck info:
2016 peterbilt 386
ISX15
Manual transmission
The hub bearings need re-torquing every 250k miles.
When is the last time this was done?.
(10-04-2022 )Rawze Wrote: [ -> ]The hub bearings need re-torquing every 250k miles.
I've only had the truck a short while and don't have that answer. I don't have the proper tools to perform this yet so I'll get it to the mechanic asap to have them re torqued. Thank you rawze.
I would think it was popped by a loss of data communication from the abs module. You might need to use different software than Insite. Jpro is pretty good as a generic software to be able to talk with abs, bcm, cecus, etc in all model trucks.
Did it tell you which wheel it's on when you scrolled thru? Maybe check the air gap on your sensor. Sometimes they will vibrate loose in the sleeve.
With a j1939 fault my first step without proper diag software would be to check fuses and power/ ground supplies to the abs module. Peterbuilts and kenworths are horrible about corrosion in the fuse pannel causing a voltage drop at the fuse. Remember with no power or ground a module can't communicate on the data link which will cause j1939 faults.... Alot of people overlook this and go directly to a non existant j1939 problem
