Is there a way to turn on, and keep on when the truck is running, to 2 footwell lights under the brake valves that come one with the dome lights when the doors are open? I don’t have a switch for them and can’t find any info anywhere.
Next to running your own switched circuit to them there isnt
(10-25-2022 )Bengy88 Wrote: [ -> ]Next to running your own switched circuit to them there isnt
I didn’t think so. I even went into the parameters on paccar esa. I knew some of the older ones had a switch in there but not seen it on the newer ones
My Kenworth has that option. The dome light switch is a 3 position switch. Off, floor lights under the center console and dome lights. Either way, get a 3 position switch to replace your dome light switch and wire in as many lights as you like
Not a bad idea but there isn’t a dome switch in mine. Works off the door jamb switch.
