Full Version: Leaking Seal Additive
Has anyone had success using AT205 RESEAL[/b] for oil leaks ?
(11-06-2022 )xlngolf Wrote: [ -> ]Has anyone had success using AT205 RESEAL[/b] for oil leaks ?
No , but I wouldn't do it. Fix the leak those snake oil leak fixers tend to cause more problems. The last thing you want to do is clog any oil passages.
I agree... the passages in the rocker arm assemblies are quite small and have limited pressures. I would think that a person would get accelerated wear in the rockers if oil flow was restricted.
Reference URL's
