attachment=8615]Ok I put the retaining rings in my 2015 kw isx15. I put everything back now when I spin it over it gives me code 4691. What could cause this? Could I have not put the rings in far enough? I used the tool Cummins sold for the job? I tightened it all the way down like it was suppose to be. Any ideas are welcome thanks Nate
What rings are you referring too? The injector cup rings?
Do a fault code search on quickserve.cummins.com
(11-14-2022 )hhow55 Wrote: [ -> ]Do a fault code search on quickserve.cummins.com
Think I’m gonna retorque the injector hold downs and retaining nuts according to QuickServe.
(11-14-2022 )Nhramember Wrote: [ -> ] (11-14-2022 )hhow55 Wrote: [ -> ]Do a fault code search on quickserve.cummins.com
it also needs to pass an injector leak test as specified in this video:
http://rawze.com/forums/showthread.php?t...2#pid69262
The fuel rail pressure commanded is 5395 and the fuel rail measured is only 141 psi. Fuel rail nationality sensor is -434psi. It has me stumped fuel filters full etc.
You got a serious leak somewhere obviously. What all did you have apart when you put the rings in?
(11-15-2022 )tree98 Wrote: [ -> ]You got a serious leak somewhere obviously. What all did you have apart when you put the rings in?
I took loose fuel rail ,quell lines and the tubes to pop the injectors out to put the retaining rings in. That’s it torqued it’s back down. Im a take it apart again tomorrow to double check everything.
