Is there a way to patch this until I can get a new one that’s back ordered and no date on when it will be available? Or if anyone has one or knows someone that has one ? Looked online and every place that shows they have one I call and they are actually out. The other ones that have them are scam websites. Part # 5394271
2017 x15 cm2350 X114B
Is it losing connection because the tab is broken? If that's the case a couple small zip ties will work in a pinch to hold the plug together, until you can get a replacement assuming the wire inside isn't broken.
(11-25-2022 )marek4792 Wrote: [ -> ]Is it losing connection because the tab is broken? If that's the case a couple small zip ties will work in a pinch to hold the plug together, until you can get a replacement assuming the wire inside isn't broken.
It’s the wire behind the tab. Looks to be 3 wires behind the tab and I circled the top wire that’s split
Should be able to de-pin the wire from the connector and get a new pin to re pin it or re use the pin with a new wire.
My local International dealer sold the pins for the International side of my truck. They make a little kit that has the tools you need to safely remove the old pins. I have also seen automotive pins at my local Advance Auto.
Here is a random kit that popped up. Cannot say it is good or not, but similar to what I use.
https://amzn.to/3gDaPJK
Google says 2010-2021 ISX
How many you need?
I have like 5 trucks with bad engines we use for parts (used of course)
(11-26-2022 )Waterloo Wrote: [ -> ]My local International dealer sold the pins for the International side of my truck. They make a little kit that has the tools you need to safely remove the old pins. I have also seen automotive pins at my local Advance Auto.
Here is a random kit that popped up. Cannot say it is good or not, but similar to what I use. https://amzn.to/3gDaPJK
That’s looks like a good kit to keep. Never know when you’ll need it like me LOL
(11-26-2022 )RollinCoal Wrote: [ -> ]Google says 2010-2021 ISX
How many you need?
Just need 1! I’ll pm you!
