12-03-2022,
Hello, I did a MM to my truck 5 years ago using MM-2 guide. CM871 cascadia 2009. It is version 1505Q. Truck runs good, but maybe there is an update to it? If so where to find one? Thank you!
(12-03-2022 )Konstantin Wrote: [ -> ]Hello, I did a MM to my truck 5 years ago using MM-2 guide. CM871 cascadia 2009. It is version 1505Q. Truck runs good, but maybe there is an update to it? If so where to find one? Thank you!
(12-04-2022 )Rawze Wrote: [ -> ](12-03-2022 )Konstantin Wrote: [ -> ]Hello, I did a MM to my truck 5 years ago using MM-2 guide. CM871 cascadia 2009. It is version 1505Q. Truck runs good, but maybe there is an update to it? If so where to find one? Thank you!
1505q?-- that is more than a few years old.. that is seriously out of date at this point. many updates since then.
You should be using version 'W'. Many fixes since that old version was used. -== like years worth of them + some cummins fixes too.
I would say you need to start over and use the official version 'W" from 10-19-2020.
PM me your e-mail address and I will see if someone can send you the proper version 'W' overlay if your trying to make the program yourself. That or get with the person who made the file and have them update it properly.
(12-06-2022 )kamiar Wrote: [ -> ]Can anyone kindly send me this "W" version? i have studied the older versions and learnt a lot, would be great to see the updates...
(01-12-2023 )Deeoux Wrote: [ -> ]Do you have to modify any map to customize the truck after using the W version?
(01-12-2023 )Rawze Wrote: [ -> ](01-12-2023 )Deeoux Wrote: [ -> ]Do you have to modify any map to customize the truck after using the W version?
version 'W'? I can only assume you are referring to a CM871.
Depends on the truck. Some trucks require different turbo tables to get the proper boost level settings.
(01-14-2023 )Deeoux Wrote: [ -> ]I read that there is an excel file named 'Some Common Boost tables.xls' that I have never seen.
