12-12-2022,
(12-12-2022 )Waterloo Wrote: [ -> ](12-12-2022 )BrandonOlsen Wrote: [ -> ]I feel your pain. I have a espar heater in my truck that doesn’t work (D2) Fan turns on for maybe 5 minutes and shuts off. Pump doesn’t attempt to run or click at all. Then get the red light with 52 code. It’s never worked since I owned the truck and the previous owner never used it. They only idled. Hope you can have a little better luck than I usually get. Good luck!
eBay and or Amazon has all the parts to get your D2 running. There are two fuel filter screens, the one in the little fuel pump is likely clogged up. Then there is another screen in the D2 unit itself that more than likely needs replacing. Here is the repair kit I used, $35, it has the two filters you need. https://amzn.to/3PjPAJK
I would also purchase a new glow plug, you will be in there, replace it. I prefer the Espar OEM parts, https://amzn.to/3hhPOEI
Here is the exhaust and I bought another for the intake side, so two of these flex pipes https://amzn.to/3FmHOKO
This fuel line kit, mainly for the hose clamps, I broke a couple of them when removing the in line fuel pump. https://amzn.to/3FNfm5W
Here is a very good video on everything you will need to know on rebuilding and cleaning of your D2 heater. https://m.youtube.com/watch?v=56HCZ0C0ORk
I rebuilt mine in October, running like a champ!
Thank you sir!
Should I order a new pump for it as well? Or would one of those things cause the pump to click even one time ? Never had anything to do with an espar heater before so this is all new to me!
