12-30-2022,
Seeing as I am working on this T-2000 fixing this bad delete, I thought I would get a few new tools to make the job faster and easier.
This little baby is the BOMB! Milwaukee 2554-20 M12 FUEL 3/8 in. Stubby Impact Wrench
https://amzn.to/3WEZvfW
I cannot get over how powerful this tiny gun is! I used it quite a few times today on stuff that was stressing my two foot flex head 1/2" ratchet. I took it to the point of bending the bar, and said nope, I'm not breaking this thing. So, for shits and giggles I grabbed that little gun, put a 3/8 to 1/2" adapter on it using a 17mm impact socket. Within seconds that bolt was loose! I used it on a couple of other stubborn bolts and nuts, and BANG! They were off! This thing is a keeper! Found a refurbed one on eBay, $125 delivered.
Then this one, another eBay find... Milwaukee 2560-20 M12 FUEL 3/8" Extended Ratchet
https://amzn.to/3VAAPnE
This ratchet was a life saver getting into places I could not, and it is damn strong, even breaking a few bolts loose. Another keeper! Very impressed to say the least, especially getting into the nooks and crannies.
And this one too, I don't quite know what to make of it yet... Milwaukee M12 FUEL 1/2" Right Angle Impact Wrench with Friction Ring
https://amzn.to/3jvignh
I tried it on a few nuts and bolts, nada. Then grabbed that little 3/8" impact, removed them with ease... But, I did get into one spot, there was no way that little gun was getting in there, and there was limited room for a ratchet, and this thing did it, removed the two bolts. I see limited use for this tool, but I will keep it, because I can see a use for it.
There is my new tool review, hope it helps someone.
