(03-23-2023 )Rawze Wrote: [ -> ]As far as things being unplugged.. you need to check out the wiring harness for proper terminating resistors. Issues like that could be a lot of the trouble with he turbo actuator.. like mr. hag mentioned... and can actually cause actuator failures too.
Here is some more detailed info on that...
http://rawze.com/forums/showthread.php?t...6#pid67656
Checked the “weather pack connector” found in that other thread. Showing 60ohm
(03-25-2023 )BRUDER01 Wrote: [ -> ]...
Trying to get a copy of this file through CT to send you, hitting a road block when I go to select ECFG file. None listed- any suggestions?
If you are referring to the CT 3.17 collection that was PM'd to you .. all the cfg files needed are also there. They get added via a separate install file that is run (called 'metafiles.exe') that will unpack all the cfg files into their appropriate places for each 3-letter code they belong to.
I pass along the correct file needed for his unit
