attachment=8888] pressure keeps dropping below commanded then ramps up and pump sounds like crap when it does it. Pressure drop was 960 in a minute ill re torque and check again today mpgs are down, power is down pump was installed 8/1/22
(04-23-2023 )Rockinbexpress Wrote: [ -> ]pressure keeps dropping below commanded then ramps up and pump
and...
(04-23-2023 )Rockinbexpress Wrote: [ -> ]... In the meantime graph your commanded and measured fuel pressure and see if your measured falls below your commanded. Like the pic I attached.
That is exactly what it is supposed to do within a given allowance .. that means nothing much whatsoever.
here is why:
http://rawze.com/forums/showthread.php?t...6#pid75536
(04-23-2023 )Rawze Wrote: [ -> ] (04-23-2023 )Rockinbexpress Wrote: [ -> ]pressure keeps dropping below commanded then ramps up and pump
and...
here is why: http://rawze.com/forums/showthread.php?t...6#pid75536
What is within reason? That's the question. How many psi should it droop below commanded pressure?
(04-24-2023 )Rockinbexpress Wrote: [ -> ]..
That is set in the programming and the allowance is set differently for various tier engines.
here are just a few of these settings that are related to your question ...
*_APC_hp_BankDevThreshold {individual cylinder bank deviation allowance}
*_APC_hp_ImaTrimEnTol {steady state tolerance}
*_APC_hp_MaxErrorDev {above/below target pressure tolerance}
*_APC_hp_MdvControlTol {undershoot tolerance}
*_QTD_hp_MaxInjPressDrop {Max allowed drop in pressure for one injector firing event before a bad injector is detected}
Basicaly, if your engine was going out of its allowed tolerance, then it would be throwing a fuel pressure or other related fault of some sort.
