05-12-2023,
Looking for thoughts and/or Ideas been down this road with this truck a couple times.
AC not Blowing Cold
Freon Is Good
Compressor working and cycling as it should. Lines or cold sweating down etc.
Changed the Thermistors with New End Caps etc. And have monitored them in DLB and appear to be working normal.
I have Diamond Logic , No AC Faults or Body Controller Faults
All Blend Doors are working Normally with no issues in cab and the bunk. Air is not Cold in either
I have monitored the Temp on the Evaporator it went down to 37 once and then went back up to around 50 with in 5 Minutes. I have reset the Body Controller a couple times and the system will begin to cool. Example the Temp on outlet of Evap will start at 75 outside Air temp dropped to around 50 and stop there. If continue to run the compressor cycles normally while monitoring High and Low pressures which are normal. But the temp of the air never gets cold.
We took the Body Control Module from a sister truck to test and same results as above.
Ambient Air Temp sensor is working normally as well monitored it on DLB
Any ideas appreciated
AC not Blowing Cold
Freon Is Good
