09-17-2016,
I use hot glue to seal up my work. I get the wire and solder up the connections. After I trim the solder down I use hot glue to seal up the work. So far its been pretty effective in keeping the harness rot down. I completely rewired my trailer after all the issues I had with the old harness. Another trick I learned was to use silicone ADHESIVE to hold your harness in place. I tucked my harness in places where there is no chance of pinching and simply gooped on some silicone adhesive and is stays in place pretty well.
https://www.facebook.com/dennisjr.stotts...8803719773
