08-23-2023,
Hello, it has been awhile since I have been on the forum, also been awhile since I have been trucking. It is good to be back..
2012 Volvo, CM2250, 936K miles, (guru tuned at 600k).
Getting ready to hit the road in a few weeks, did a service, put the fuel filter on dry as usual. Usually cycle the key 6 times for the lift pump to fill the filter.. cycle the key, no lift pump noise.. pulled the pump and hooked it direct to a battery. Nothing, if it tap on it it will run just a bit but very weak.. so I know the pump is bad.. pulled the relay.. no voltage on pin 30 with key on..
Now the problem, I cannot for the life of me find the fuse that I hear controls voltage to the relay. I found one in the outside fuse panel that is for the NOX and it is ok..
Any ideas would be appreciated before I tear deeper into this wire harness.. does Volvo even use a fuse between the relay and the battery?
Thank you, JMBT
Thank you, JMBT
