How do you determine when rods should be replaced? Currently inframing an X15 with 530k miles , should they be replaced or only rebushed?
I always have the machine shop check them for bend, twist and cracks.
Always plan an engine rebuild with a million miles as the goal ...
Think of it this way .. There is no way that you will get 1.5 million on a set of original rod bushings.
The rods yes, if they are not bent or damaged, cracked, etc., but not the bushings.
So with 500k on them already, then at a bare minimum, they need new brass wrist pin bushings, or they will send a piston thru the block before it gets another million on the odo.
all the rest of this stuffs needs to be done as well....
http://rawze.com/forums/showthread.php?t...6#pid70606
and...
ref:
http://rawze.com/forums/showthread.php?t...3#pid48553
Injectors 5 and 6, curious what caused 6 to be darker colored, currently in framing due to head gasket failure at #1. X15 530k miles
That injector ran hotter than the rest, most likely for the same reasons that its being inframed in half the expected time it is supposed to be.
= Big power + low rpm, high torque abuse from bad driving habits, ... and/or bad delete programming... Take your pick of such ...
An abuse of the engine that defeated its expected longevity, in one way or the other.
Lets put it this way ...
Do you think that if I owned it, that it would have only lasted 530k miles before a liner danced in the block like that?.
I Don't know about anyone else, but I actually want to make a long term profit off of my equipment,.. and not drop $25,000+ into it 2x more often than it should be... I don't care how much slower it has to go up the hills!. hence, the first da$mn thing that I would have done after purchase would have been to RE-GEAR THE REAR ENDS CORRECTLY vs. the freight/weights I was hauling .. AND TURNED THE DAMN TORQUE DOWN TO ABOUT 1760 OR SO MAX!. And any PTO operations would have been re-geared so that the engine ran 1500-1600RPM to operate that too!.
I think it’s very common on 2350’s and 2450’s to burn the 5th and 6th injector since they removed the 7th injector the 871’s and 2250’s had.. right?
