Hey I got another question can a bad primer pump get air in your fuel system. I’m just curious learning more about this isx 15 2350 everyday. Thanks Nate
I would say highly unlikely, but not completely impossible.
I would suspect worn/damaged fuel hoses long before I suspected a primer pump introducing air into the system. Even more likely would maybe be a bad sealing washer or two on the suction side banjo bolt to the pump. But even then....not completely impossible, not definitely not "common" in any sense.
