What is the best oil pump besides Cummins on the market? I know I can do oem but checking for rod bearings and main bearings since I just hit the 1 million mark on my 2015 kw t680. I wanted to get here and did now I wanna do a new oil pump and the bottom end. Thanks everyone
OEM only on internal parts. That is the only answer you will get from the reputable people here. That is one place you don't want to skimp. Something non-critical like a tensioner, belt, etc I would go with aftermaket.
Rawze will have a fun answering this :-)
Stop trying to save a nickel to spend a dollar later.
Replace oil pump OEM and Shim Correctly and make sure to double check of size bearing or mismatch.
(02-16-2024 )Pd6cas2 Wrote: [ -> ]Rawze will have a fun answering this :-)
Replace oil pump OEM SHIM. Correctly and make sure to double check of size bearing or mismatch.
I could not have said it better myself..lol
