the canadian salt have got the best of this fill plug. heated it, tried a pipe wrench but doesn't get a proper grip, tried a chisel and nope doesn't even budge. The 1/2 inch socket kept spinning in it it because the rust decayed out the hole. The bottom plug was ok, i cracked it loose but didn't run it out because i haven't open the fill plug yet.You guys have any idea besides welding a nut on it to pull it out? thanks
Most common cause is not so much the rust ... but likely some yahoo not using a proper torque wrench, and not setting it to the correct torque when putting it in during an oil change.
Smacking it with a hammer a few times hard, or using an air-hammer to jar it a bit + heating it up a decent amount before trying to break it loose might help.
Irwin makes an extractor set (53227) that you might be able to use to get that plug out. You can get the set from amazon.
https://amzn.to/3Wce3pZ
(04-06-2024 )Pete379 Wrote: [ -> ]Irwin makes an extractor set (53227) that you might be able to use to get that plug out. You can get the set from amazon.
Bought that Irwin kit and it worked.
