Full Version: 2007 isx cm870
Just bought a 2007 386 with a cm870. It’s got 3.36 rears and 10 speed. It’s got tall rubber 24.5 on. My question is would going back down to low pro 22.5 be better for this setup or keep the big rubber? Thanks
yes.. and get rid of those horrible rears that are too tall for anything but hauling flowers and lugging the engine to an agonizing death too.
@rawze can you give me a part number for a fan clutch for this 870 ? Thank you
(09-10-2024 )Brandon32382 Wrote: [ -> ]@rawze can you give me a part number for a fan clutch for this 870 ? Thank you
Engine parts are easy to look up yourself. Simply register the engine ser# on quickserv.com and you get same access for parts and manualz as stealers#its for that. Its free.
Fan clutch for a particular vehicle however, is dependent on what vehicle and options that it came with.
You should find out what brand and type clutch it has installed and then look it up.
https://catalog.hortonww.com/index.html
Reference URL's
