| Losing engine gauges, speedo, and fan staying on - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: Losing engine gauges, speedo, and fan staying on (/showthread.php?tid=10141) Pages: 1 2 |
RE: Losing engine gauges, speedo, and fan staying on - Mrkentee - 05-27-2025 (05-27-2025 )Colter Wrote: This would be a fun one to find, elogs are always terrible at codes, I assume one tank guage isnt working. Without a 1117 you ECM power supply should be good, the fact the the ABS seems to be flagging a voltage issue opens up the rest of the wiring. Voltage gauge stays strong, not affected. Everything in the battery box is ok. Only has one fuel tank gauge. RE: Losing engine gauges, speedo, and fan staying on - marek4792 - 05-27-2025 Check your firewall pass through plug(s) too! Sounds exactly like my other truck did when it got wet outside. Cleaned it up with contact cleaner and plugged and unplugged it a few times and hasn't done it after that. |
