Turbocharger? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Turbocharger? (/showthread.php?tid=10235) Pages: 1 2 |
RE: Turbocharger? - Ravenwood - 07-30-2025 Turns out the IMAP fault code was from before I fixed all the fuel leaks and I forgot to delete it! Sometimes I wonder about myself lol. Could this engine brake issue be a weak solenoid? 2nd stage looks like it may be the culprit. No fault codes today but the shaking and popping seems to be on a long enough pull that oil temperature tops out at around 235-240. Could that cause the solenoid to all of a sudden activate and fight itself? RE: Turbocharger? - Rawze - 07-31-2025 (07-30-2025 )Ravenwood Wrote: Turns out the IMAP fault code was from before I fixed all the fuel leaks and I forgot to delete it! Sometimes I wonder about myself lol. no, but bad jake rockers, or bad solenoid could cause it to act up/leak, and partially activate. |
