| DD13 SPN 3251fmi 21 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Freightliner related help (/forumdisplay.php?fid=75) +--- Thread: DD13 SPN 3251fmi 21 (/showthread.php?tid=10393) Pages: 1 2 |
RE: DD13 SPN 3251fmi 21 - Therealarw - 11-14-2025 (11-14-2025 )mikkhh Wrote: DD13 has separate aftertreatment control module A C M for scr and dpf , it is not integrated into engine ecu. EGR is controlled directly by engine ecu. I have to look and see if I can get those readings with JPRO. I might have to get a bootlegged DiagnosticLink because I know you can get a little deeper with sensor readings and voltages. JPRO doesn't get me all that data for some reason unfortunately RE: DD13 SPN 3251fmi 21 - Therealarw - 11-14-2025 (11-14-2025 )Rawze Wrote:I never really thought about that.. When I took the dpf filters out though they were actually really clean. They even felt really light too so it's been kinda hard to pinpoint exactly what it is that's causing the CEL but with these detroits it could literally be anything I'm going to have to really dig into it soon(11-13-2025 )Therealarw Wrote: ... RE: DD13 SPN 3251fmi 21 - ralt965 - 01-02-2026 Check the connector plug at the acm. These can be located in strange areas and my experience is with having a lot of plug sealing issues where water intrusion happens. I’ve even just had contact pins in MCM and acm fail just becoming loose. |
