| Dd15 crank no start - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: Dd15 crank no start (/showthread.php?tid=10541) Pages: 1 2 |
RE: Dd15 crank no start - mechanixrds - 04-08-2026 (03-30-2026 )PROMOBILE Wrote: Still looking for any info if anyone has any other ideas Have you tried priming the fuel system through the Compu-check port on the filter housing with a J-47912 tank or equivalent? RE: Dd15 crank no start - tree98 - 04-09-2026 I would load test the wires from the sensor to the ECM. If that checks out its almost gotta be the ECM itself. As long as you're 100% sure the sensor is good. You could back probe the sensor and see if it's sending voltage back and forth to the ECM. Also are you sure you have good software that's correct for this engine? |
