2006 cm870 air in injector leakdown test - Printable Version
+--- Thread: 2006 cm870 air in injector leakdown test (/showthread.php?tid=10564)
Pages: 1 2
RE: 2006 cm870 air in injector leakdown test - CTTOWING - 04-03-2026
It actually followed the injector, we have been careful with installation and adjusting them. Truck has been sitting for about year and a half. I will check fuel quality to make sure injectors are not getting contaminated from the fuel. I guess I will get 3 more cummings injectors and see if they will warranty the one. I will drain tanks and start with fresh fuel to be on the safe side.
RE: 2006 cm870 air in injector leakdown test - Rawze - 04-03-2026
(04-03-2026 )CTTOWING Wrote:  It actually followed the injector, we have been careful with installation and adjusting them. Truck has been sitting for about year and a half. I will check fuel quality to make sure injectors are not getting contaminated from the fuel. I guess I will get 3 more cummings injectors and see if they will warranty the one. I will drain tanks and start with fresh fuel to be on the safe side.
A 10-micron filter in the davco unit helps tremendously towards keeping injector and the fuel system clean.
