Electrical problems - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Electrical problems (/showthread.php?tid=1514) Pages: 1 2 |
RE: Electrical problems - DDlighttruck - 11-14-2019 (11-14-2019 )Delly876 Wrote: Electrical problem I had a bunch of these same issues, I changed my engine harness out and it fixed 95% of my problems RE: Electrical problems - Magard - 11-14-2019 Isn’t there a mega fuse somewhere. I would be changing that. Volvo has one. Also I had a international cab over flat floor that had a mega fuse blow on me once. They can crack and not be connecting good. 150 amp fuse or so. RE: Electrical problems - DVT873 - 11-14-2019 I 2nd Waterloo. The starter has a solenoid on top of it. It is used as a junction point. Take the nut off. Be careful, cleaning what threads you can see with a brush will help. There will be several wires besides the battery cable. They may look fine but the terminal ends can be bad. Taking them off and looking is the only way to know for sure. One of those wires will be a cab power feed. From there to the ignition switch. Problems there same as turning off the key. Interesting code. On NAV ECM's loose of the ignition power just shuts it off and leaves no codes. Maybe Cummins gets switched power on more than one input. Engine harness can be an issue. Guy I know went thru that. I'll see if he remembers detail. Moonshine degrades his memory. Post your VIN. Might be able to link you to a wiring diagram. RE: Electrical problems - jamie640 - 04-18-2021 If you get a SPN 91 (APP code) on a 2011 International Prostar with a Maxxforce 13, this was my problem incase somebody runs into this... I pulled off the most rearward connector on what i believe to be the Fuel Control Modual (Behind the fuel filter housing) NOT the ECM. I soaked the pins with electrical contact cleaner and blew off with compressed air and cured the spn 91 problem. Iam missing my little black plastic splash shield in front of the connector and recently washed the engine, Iam guessing there was some corrosion on the tiny pins as they are so small it is hard to see. RE: Electrical problems - MRETRANS - 05-02-2022 (02-27-2017 )Waterloo Wrote: You need to take the truck to the dealer and see what they pull up on Diamond Logic... I had the same issues, it was my compass... Yes, the compass. The compass is a canbus module in your fuse block area... The dealer should be able to figure this out in less than a minute or two. If it is the compass module, the dealer will want around $400 for it... I found a new one on eBay for $20 delivered. It fixed my problem Is there any way you can send a picture of the Compass? What does it look like in the fuse box? I don’t think I have one all I see are fuses and relays |
