Injector tests - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Injector tests (/showthread.php?tid=2177) Pages: 1 2 |
RE: Injector tests - marek4792 - 09-27-2017 (09-27-2017 )snailexpress Wrote: marek4792 Wrote:you're right I deleted it from my post. RE: Injector tests - snailexpress - 09-27-2017 [/quote] A video would be great. Just to make sure I did it right. If I did it right there was no delay it switched instantly on rare occasions it was delayed by about a second. [/quote] I had same problem with injector test. The test was successful probably once but mostly stopped every time on different injector or state. I didn't perform test after damand-g. Not sure it will run as with DPF Actuator test video will shoot little bit later, it too bright now video is poor quality. |
