| 2250 issues...need advice - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: 2250 issues...need advice (/showthread.php?tid=2373) Pages: 1 2 |
RE: 2250 issues...need advice - Beaver - 11-12-2017 (11-12-2017 )Squish099 Wrote:(11-12-2017 )Beaver Wrote:Yup changed that 1 and the delta-p sensor. Ran a little better but still bad(11-12-2017 )Squish099 Wrote: Boost sensor in on the intake, driver's side, sits behind/underneath the wiring harnessSo the IMap sensor then...right? RE: 2250 issues...need advice - Beaver - 11-12-2017 (11-12-2017 )Squish099 Wrote:(11-12-2017 )Beaver Wrote:I've had it up to 1750 and the most boost at that rpm is about 28. Anything under 1500rpm and the boost is below 20psi(11-12-2017 )Rounded_nut Wrote: How much boost on full Jake?About 24psi RE: 2250 issues...need advice - Squish099 - 11-12-2017 I really don't know what the jakes boost to from factory.. Mine is mm-2 anything close to or over 1500 rpm and my jake boost to 30-32 psi.. Change back pressure sensor, clear out egr system from exhaust manifold to intake manifold. I used 2 gallons of Castrol super clean, not diluted at all, then rinsed everything out well and blew it dry with shop air.. RE: 2250 issues...need advice - Billdozer2 - 11-12-2017 My 2250 shakes a bit while using the jakes if I haven't used the jakes in a while. Like after driving though a town that doesn't allow jakes. After I've used the jakes a couple times on full strength, the shaking stops. On full strength at 1500 rpms, the boost is a little over 30 psi. (Tough to tell actual psi on my Volvo gauge.) RE: 2250 issues...need advice - snailexpress - 11-13-2017 Many things could affect jake brake performance. Overhead set - was it done by reputable mechanic recently? Soot clogged oil passages could Not working solenoid could ECM settings in INSITE could Different edition of calibration in ECM RE: 2250 issues...need advice - Beaver - 11-13-2017 The overhead was done at Peterbilt about 2 months ago but lets be honest about that one lol. I'm pretty sure the ecm and settings are good but i dont have insite to check andi cant afford it right now, nor do i trust any particular shop to help me there. My last oil sample, soot was 0.2. The 1st oil sample i did from the original oil that I had when i picked it up had the soot at 0.7 ao at least its on the way down but you may be right about the soot in the overhead. I think maybe peterbilt didnt check that the jake brake connections in the overhead were tight or plugged all the way in. |
