| Fuel mileage. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Fuel mileage. (/showthread.php?tid=2472) Pages: 1 2 |
RE: Fuel mileage. - Streachy - 12-12-2017 (12-12-2017 )Rawze Wrote:(12-12-2017 )Streachy Wrote: ... Ok. Thanks. I’ll give it a try RE: Fuel mileage. - Streachy - 12-14-2017 (12-12-2017 )Rawze Wrote:(12-12-2017 )Streachy Wrote: ... Well. You may or may not believe this but in talking with Unilevers , he had suggested a few things. The last being pull a piece of the exhaust off close to the turbo. In doing that the truck ran normal. Further investigation I discovered that the remaining 1 inch of material I left on the outer edge of the DOC/DPF broke off and plugged the screen in the DEF decomp tube. I never would’ve thought. Anyways it’s all good. Thanks to all who had advised me in this matter. I guess the best idea is to remove all of that material. Happy trucking RE: Fuel mileage. - Rawze - 12-14-2017 (12-14-2017 )Streachy Wrote: Well. You may or may not believe this but in talking with Unilevers , he had suggested a few things. The last being pull a piece of the exhaust off close to the turbo. In doing that the truck ran normal. Further investigation I discovered that the remaining 1 inch of material I left on the outer edge of the DOC/DPF broke off and plugged the screen in the DEF decomp tube. I never would’ve thought. Anyways it’s all good. Thanks to all who had advised me in this matter. I guess the best idea is to remove all of that material. Happy trucking A quote from this post... Quote:... reference... http://rawze.com/forums/showthread.php?tid=2472&pid=21269#pid21269 RE: Fuel mileage. - Rawze - 12-14-2017 thanks for sharing this problem and solution with everyone. May it be wise words for those getting those kinds of things done so that they can ensure what they had done is correct. You should be lucky that no other damage occurred while the exhaust was blocked up. RE: Fuel mileage. - Streachy - 12-15-2017 (12-14-2017 )Rawze Wrote: thanks for sharing this problem and solution with everyone. May it be wise words for those getting those kinds of things done so that they can ensure what they had done is correct. Very lucky. We really babied it when it was running hot to get it home,and didn’t keep working the truck in that state. The part that confused me is that it did it 2 weeks ago and after a thorough inspection of the air to air and cleaning out the IMAP the thing when back to normal. Anyways, pretty thankful to Unilevers for His help and experience |
