ISB 6.7 - Crankcase pressure, constant clogged DPF - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: ISB 6.7 - Crankcase pressure, constant clogged DPF (/showthread.php?tid=3893) Pages: 1 2 |
RE: ISB 6.7 - Crankcase pressure, constant clogged DPF - zbot - 01-07-2019 (12-22-2018 )Moose Wrote: Check with Ford as some of these were victims or bad air cleaner/piping resulting in dusting/early engine failures. You weren't kidding https://ford.oemdtc.com/828/fault-codes-555-and-556-2012-2013-ford-f-650-f-750-cummins RE: ISB 6.7 - Crankcase pressure, constant clogged DPF - Moose - 02-03-2019 Right before my exit from the big C I worked two tow trucks cases with this problem. I kinda refused to believe an engine with less than 100k miles was dusted... a couple days later the correct orifice came in and we went and road tested with the manometer...... Both were F650 with 6.7's. one had the bad clamp the other a hose was split and was ingesting. Guy I knew at Ford clued me into the issue. Once we started taking the intake and CAC system down it was very clear what caused it..... |
